http://www.amnh.org/nationalcenter/youn ... aidan.html
http://inhabitat.com/13-year-old-makes- ... -sequence/
While most 13-year-olds spend their free time playing video games or cruising Facebook, one 7th grader was trekking through the woods uncovering a mystery of science. After studying how trees branch in a very specific way, Aidan Dwyer created a solar cell tree that produces 20-50% more power than a uniform array of photovoltaic panels. His impressive results show that using a specific formula for distributing solar cells can drastically improve energy generation. The study earned Aidan a provisional U.S patent - it's a rare find in the field of technology and a fantastic example of how biomimicry can drastically improve design.
Aidan Dwyer took a hike through the trees last winter and took notice of patterns in the mangle of branches. His studies into how they branch in very specific ways lead him to a central guiding formula, the Fibonacci sequence. Take a number, add it to the number before it in a sequence like 1+1=2 then 2+1=3 then 3+2=5, 8, 13, 21 and so on a very specific pattern emerges. Turns out the pattern and its corresponding ratios are reflected in nature all the time, and Aidan’s keen observation of how trees branch according to the formula lead him to test the theory. First he measured tree branches by how often they branch and at what degree from each other.
To see why they branch this way he built a small solar array using the Fibonacci formula, stepping cells at specific intervals and heights. He then compared the energy output with identical cells set in a row. Aidan reports the results: “The Fibonacci tree design performed better than the flat-panel model. The tree design made 20% more electricity and collected 2 1/2 more hours of sunlight during the day. But the most interesting results were in December, when the Sun was at its lowest point in the sky. The tree design made 50% more electricity, and the collection time of sunlight was up to 50% longer!”
His work is certainly piquing the interest of the solar industry, and even more impressively he is demonstrating the power of biomimicry — a concept that many see as the pinnacle of good design, but one that thus far has been exceptionally difficult to achieve. Way to go!
Googlês:
Enquanto a maioria dos 13-year-olds gastar seu tempo livre a jogar jogos de vídeo ou de cruzeiro Facebook, uma motoniveladora 7 foi caminhadas pela floresta descobrindo um mistério da ciência. Depois de estudar como o ramo de árvores em uma maneira muito específica, Aidan Dwyer criou uma árvore de célula solar que produz energia 20-50% mais do que um conjunto uniforme de painéis fotovoltaicos. Seus resultados impressionantes mostram que o uso de uma fórmula específica para a distribuição de células solares pode melhorar drasticamente a geração de energia. O estudo ganhou Aidan uma patente provisória EUA - é um achado raro no campo da tecnologia e um exemplo fantástico de como biomimicry pode melhorar drasticamente design.
Aidan Dwyer pegou uma caminhada por entre as árvores no inverno passado e tomou conhecimento de padrões no mangle de ramos. Seus estudos sobre como eles ramo de formas muito específicas levá-lo a uma central de orientação fórmula, a seqüência de Fibonacci. Pegue um número, adicioná-lo ao número antes em uma seqüência como 1 +1 = 2, então 2 +1 = 3 então 3 +2 = 5, 8, 13, 21 e assim por diante um padrão muito específico emerge. Acontece que o padrão e suas relações correspondentes são refletidas na natureza o tempo todo, e observação aguçada Aidan de como ramo de árvores de acordo com a fórmula de levá-lo para testar a teoria. Primeiro mediu galhos de árvores por quantas vezes eles se ramificam e em que grau um do outro.
Para ver por que eles ramo Desta forma, ele construiu uma pequena série solar usando a fórmula de Fibonacci, pisando células em intervalos específicos e alturas. Em seguida, ele comparou a produção de energia com células idênticas set em uma fileira. Aidan apresenta os resultados: "O projeto da árvore de Fibonacci desempenho melhor do que o modelo de tela plana. O projeto da árvore feita de eletricidade 20% mais e coletados 2 1 / 2 mais horas de sol durante o dia. Mas os resultados mais interessantes foram, em dezembro, quando o Sol estava no seu ponto mais baixo no céu. O projeto da árvore feita de eletricidade 50% mais, eo tempo de coleta da luz solar foi até 50% mais tempo! "
Seu trabalho é, certamente, despertando o interesse da indústria solar, e ainda mais impressionante que ele está demonstrando o poder de biomimetismo - um conceito que muitos vêem como o auge do bom design, mas que até agora tem sido excepcionalmente difícil de alcançar. Caminho a seguir!
Mentes brilhantes... com 13 anos!
Re: Mentes brilhantes... com 13 anos!
A nova energia na cidade!
Grande miúdo!
Ei-lo
American Museum of Natural History
E a sua proeza:
Os painéis solares do dispositivo estão colocados em forma de ramos de árvore e dispostos de acordo com a sequência de números de Fibonacci. O aparelho é perfeito para ser utilizado em áreas urbanas, onde o aproveitamento da energia solar é dificultado.
Mais 20 a 50% de energia
Para testar a sua hipótese, o jovem construiu dois coletores solares constituídos pelo mesmo número de painéis para os comparar: um deles copiava a disposição dos ramos de uma árvore e o outro era uma superfície plana composta por painéis colocados lado a lado.
Segundo Aidan Dwyer, os resultados mostraram aquilo suspeitava: o coletor-árvore gerou entre 20 e 50% mais eletricidade do que o de design normal.
O jovem cientista defende que é o padrão Fibonacci que permite às árvores acompanhar o movimento do sol no céu de forma a captar energia solar continuamente durante o dia, o que não é possível como os painéis dispostos lado a lado com uma mesma orientação.
http://www.boasnoticias.pt/noticias_EUA ... _7733.html
Grande miúdo!
Ei-lo
E a sua proeza:
