solarbike1 Escreveu:Olá pessoal ando a considerar em comprar um gerador eólico.
ando a ver de 500w a 1000w .
o que sucede é que tenho um sistema 12v.... mas sei que mais tarde vou passar para um maior de 24v.
existe forma de comprar uma eólica de 24v e usar num sistema 12v?
Vê este site:
http://www.navitron.org.uk/wind-power. Para além de as venderem, o fórum deles sobre eólicas é muito completo.
E nessas FAQ's encontras:
What is the recommended system voltage and wattage, and why?
It is a matter of personal preference, and there are many variables that affect this decision. Often it is necessary to chose a wind turbine that has to integrate into an existing system - eg photovoltaics, an existing battery bank or a DC backup system. In this case, your choice of turbine will be determined to some extent by the existing system voltage. If you are not constrained by this, you need to work out how much power you require, and how much power is available. Wind power varies enormously from one site to another, and even at different locations on the same site, but as a general rule, in a good location you will expect about 30% of the maximum output when you average out over the whole year. You can expect proportionately more power during the winter months, and periods of bad weather. Incidentally,
it is possible to boost the performance of the wind turbine in very low wind conditions by using it will a smaller battery bank than intended. For example, if you use a 500W 36v turbine to charge 24v batteries, then the power curve will be shifted towards lower wind speeds, but with a penalty of having a lower maximum output. One customer reported that his Navitron 500W turbine massively exceeded the output of a Proven 2kW turbine in almost all conditions, when used with a 24v battery.
Daqui tiras duas coisas: mesmo num bom local no UK, a produção esperada é de 30% do output máx. da turbina. Não só podes usar uma de 24V num sistema de 12V como isso pode incrementar a produção em situações de muito pouco vento, com a penalização de diminuir o output máximo que seria possível usando a turbina de 24V num sistema de 24V. Não entendo nada do assunto mas pelo que percebi a rotação adapta-se ao que o sistema extrai a jusante da turbina. As baterias funcionam como um travão à turbina. Vê esta FAQ:
Can I use the 200W/300W wind turbine with 12v (or 500W/1000W turbine on 24v)?
Yes, you can use any of the wind turbines that we sell on 24v or 12v systems. This will mean that the maximum power output is reduced as
the battery will act as a brake. For example,
if you use the 500W (36v) turbine with 12 volt systems expect 1/3 of the power, so around 180Watts max, on a 24 volt system the same machine will produce about 365 Watts max. On the other hand your cut in speed is much reduced. If you were to use a 200 Watt (24v) Navitron wind turbine on a 12v system, its cut in speed will be reduced from around 4.5m/s to around 2.5m/s and on sheltered sites, you will may much more power out of it over a week.
