Inversor de rede 600 w
nunom967
Mensagem por nunom967 » domingo jan 05, 2014 10:48 pm
Viva!
Comprei no ebay alemão este inversor de rede chinês:
LiveLife Brings You Green Life - 600 Watt Grid Tie Power Inverter 22-60VDC to 230VAC, fit 36v PV within 720wSpecification :
Power: 600w
Solar Panel: >600w
DC MAX input: 720w
DC input range: 22-60VDC
MPPT Voltage: 31-40V
DC MAX current: 50A
AC MAX output: 650W [/color]
AC output range: 230VAC(190-260VAC)
Frequency range: 50Hz/60Hz(Auto control)
Power Factor: >97.5%
THD: <5%
Phase Shift: <2%
Efficiency: 230VAC(190-260VAC)
Peak Efficiency: >85%
Stable Efficiency: >84%
Protection: Islanding; Short-circuit; Converse connection; Low Voltage; Over voltage; Over temperature Protection
Work Temperature: -25°C —65°C
Work Humidity: 0%~90%RH non-condensing
Grade of Waterproof: Indoor design
Show: LED
Cooling: Fan
Stand-by Power: 2-3W
EMC: EN61000-6-3:2007 EN61000-6-1:2007
Grid Disturbance: EN 50178+EN 62109-1+VDE0126-1-12
Grid Detection: DIN VDE 1026 UL1741
Certificate:CE
Mounting Dimension:16*13CM
Packing Accessory
Microinverter, AC Cord, User Manual, Warranty Card
Net Weight: 1.3KGS/PC
Gross Weight: 2.0KG/PC
Inner Box: 30*20.3*11.3CM
Carton: 42*31.5*35.5CM(6pcs/ctn)
Ligando por exemplo 3 painéis destes:
Models HIT-xxxHDE4
Electrical data 240
Maximum power (Pmax) [W] 240
Max. power voltage (Vpm) [V] 35.5
Max. power current (lpm) [A] 6.77
Open circuit voltage (Voc) [V] 43.6
Short circuit current (Isc) [A] 7.37
Warranted min. power (Pmin) [W] 228.0
Maximum over current rating [A] 15
Output power tolerance [%] +10/-5
Max. system voltage [Vdc] 1000
Temperature coeff. of Pmax [%/°C] -0.30
Temperature coeff. of Voc [V/°C] -0.109
Temperature coeff. of Isc [mA/°C] 2.21
A ligação dos 3 módulos (3*240W=720W, que é o recomendado para este inversor) teria que ser em paralelo(?) para a VDC ficar dentro dos limites do inversor (DC input range: 22-60VDC ), neste caso 35,5V.(?)
Isso iria implicar amperagens maiores do lado DC (W=V*A) o que por sua vez implicaria também cabos mais grossos, dependendo da distancia a percorrer.(?)
Apos ter estado a ler alguns tópicos aqui do fórum, por exemplo o http://novaenergia.net/forum/viewtopic.php?f=46&t=16283
em que é referido o stecagrid500 (Maximum input voltage 230V e MPP voltage for rated output 106 V ... 170 V) a diferença é também na DC Maximum input current 5A no steca para 50A no LiveLife.
Resumindo, não haverão duvidas,
stecagrid500 para ligar módulos em serie, VDC maiores logo AmpDC menores logo cabos mais finos..(para a mesma potencia que em paralelo?)
LiveLife para ligar módulos em paralelo, VDC menores, AmpDC maiores logo cabos mais grossos..(para a mesma potencia que em serie?)
Se os painéis forem colocados a uns 12 metros do inversor que cabos teriam que ser usados(?) iriamos ter ampDC de que valores (?)
Para 720W(240Pmax*3) / 35.5V(VPM) = 20Amp
Qual seria o cabo para transportar 20AmpDC por 12 metros..(?)
Se bem que o inversor LiveLife tenha custado 1/3 do preço do stecagrid500, admita mais AC MAX output: 650W para os 500W do steca dá-me ideia que fica a perder nas considerações expostas anteriormente.
Pelo que li no tópico referido também não deverá ser ultrapassada a DC MAX input (720w para o caso) correndo o risco do mesmo arder, e se for ultrapassada a DC input range: 22-60VDC (?)
MCumps,
2,29 KW Paineis Solares
K2 Systems - Roof Anchor System
StecaGrid 2000+
Steca PR 3030
BOSCH - Termossifão 200L com Módulo Solar
accoelho
Re: Inversor de rede 600 w
Mensagem por accoelho » segunda jan 06, 2014 8:26 pm
Nos inversores de rede chineses fica-se a perder na eficiência.
Com os paineis do exemplo,dificilmente atinge o pleno rendimento mensionado.
Logo o inversor de rede dificilmente chegará ao limite,em W e DC.
Cabos de min 6mm^2.
nunom967
Mensagem por nunom967 » domingo jan 26, 2014 5:17 pm
Liguei 1 painel dos referidos ao inversor e com sol sem nuvens, depois de o MPPT estabilizar/fixar, no medidor consumo elétrico do ALDI dá uns valores muito estranhos:
20,41A
4612W
(226V)
Não será o medidor adequado para estas leituras presumo.
StecaGrid 2000+
Steca PR 3030
JMLorenzo
Mensagem por JMLorenzo » terça jan 28, 2014 8:44 pm
Era bom que um painel desse valores destes :D
O medidor do Aldi é para medir consumos de aparelhos elétricos, por acaso nunca experimentei a ver se faz medições ao contrario.
Mensagem por MRider » terça jan 28, 2014 8:51 pm
O medidor barato do Lidel só mede num sentido.
Mas eu por acaso tenho um que comprei no eBay e mede nos 2 sentidos :-)
nunom967
Mensagem por nunom967 » quinta mai 22, 2014 3:53 pm
já tenho um medidor bidirecional.
Por estes dias, agora após as chuvas que lavaram os paineis, consegui atingir os 229W, com este inversor e um painel de 240W, o que equivale a uma eficiencia de 95,41% do inversor.
StecaGrid 2000+
Steca PR 3030
accoelho
Mensagem por accoelho » sexta mai 23, 2014 10:44 pm
resta saber se esse medidor está com boa eficiencia.
ja foi um bom pico.
dá pra teres uma ideia do que esse sistema vai produzindo.
o pouco conta-se e o nada não se vê......
