estão a publicitar a descoberta mais no sentido de usar o sistema juntamente com paineis solares para autonomia energética nas habitações, mas claro que tem potencial para o mesmo impacto na mobilidade.
muito mais detalhes nos links abaixo.
http://www.eetimes.com/showarticle.jhtm ... cid=nl_eeta liquid catalyst was added to water before electrolysis to achieve what the researchers claim is almost 100-percent efficiency. when combined with photovoltaic cells to store energy chemically, the resulting solar energy systems could generate electricity around the clock, the mit team said.
"the hard part of getting water to split is not the hydrogen -- platinum as a catalyst works fine for the hydrogen. but platinum works very poorly for oxygen, making you use much more energy," said mit chemistry professor daniel nocera. "what we have done is made a catalyst work for the oxygen part without any extra energy. in fact, with our catalyst almost 100 percent of the current used for electrolysis goes into making oxygen and hydrogen."
nickel oxide catalysts are currently used to boost the efficiency of electrolyzers, and they worked equally well in mit's formulation, nocera acknowledged. he added that the toxicity of nickel oxide forces the use of expensive, hermetically-sealed water containers. mit's patented catalyst formulation is "green," nocera said, and can be used in inexpensive open containers.
"nickel oxide can't be used around anything else in the environment because of corrosion -- even the carbon dioxide in the air will react with it to make carbonates," said nocera. "but our catalyst uses abundant materials that don't react with environment."
mit's patented formulation of cobalt phosphate was dissolved in water. when the electrical current is passed through it to initiate electrolysis, the catalyst attached itself to the oxygen electrode to increase its efficiency. when the electrical current was turned off, the cobalt phosphate dissolved back into water.
http://web.mit.edu/newsoffice/2008/oxygen-0731.html (tem um video)
