Chevy Volt by GM & Ampera
Re: Chevy Volt by GM
the ampera has a big future ahead of it! vauxhall has released this cryptic teaser shot ahead of the geneva motor show, along with a handful of details of what will be on display.
topping the bill will be an all-new concept that illustrates the firm’s claim that “size and comfort do not need to be sacrificed for a vehicle to be environmentally efficient” - suggesting it will take the form of a luxury four-door coupe or even an suv. what it won't be is an mpv, insiders say.
the concept will feature the same voltec plug-in hybrid powertrain as the ampera - which uses electricity as its primary power source supplemented by a small petrol engine for charging the batteries. more will be revealed closer to the car’s official unveiling.
also on the stand in geneva will be the revised corsa range, which gets a mid-life makeover and a new line-up of economical engines. in fact, every new corsa bar the vxr model will exceed 50mpg when fitted with a manual gearbox. the latest ecoflex is the star of the range though - not only does it gain 20bhp but achieves a combined economy of 76.3mpg and co2 emissions of just 98g/km.
read more: http://www.autoexpress.co.uk/news/autoe ... z0fivsamox
mais info sobre o dito em pt!
Seal
Re: Chevy Volt by GM & Ampera
Mensagem por Seal »
gm says volt system will have 8-year 100.000-mile warranty
general motors co., preparing to launch the first u.s. mass-market plug-in hybrid, will offer buyers of its chevrolet volt an eight-year, 100,000-mile warranty on the lithium-ion battery's 161 components.
the warranty also includes the battery's thermal management system, charging system and electric-drive components, gm said today.
the volt, which goes on sale in october or november, can run for up to 40 miles on battery power before it switches to power from a gasoline-powered engine. a battery can charge in 8 to 10 hours on 120-volt power or about four hours through a 240-volt hookup.
gm intends for the warranty length to give customers confidence in the volt's unfamiliar plug-in technology, said micky bly, gm's executive director of global electrical systems, today at gm's battery plant in brownstown township, mich.
it's one less question for the dealer,” bly said. gm has not announced the warranty for the volt's gasoline-powered engine, but bly said it would be at least as long as gm's standard five years or 100,000 miles.
the volt battery's longevity stems in large part from the liquid heating and cooling system that keeps the battery at optimal temperatures. the volt is the only such mass-market vehicle with a liquid-powered thermal management system, gm said.
for example, the nissan leaf electric vehicle has an air-cooled battery. nissan hasn't released warranty information for the leaf, which goes on sale in december.
the brownstown plant has been building prototypes for volts since january and will soon start batteries that will go on vehicles destined for customers' garages.
gm diz que sistema volt terá 8 anos de garantia 100,000 milhas
general motors co., se preparando para lançar o primeiro e.u. mercado de massa híbrido plug-in, vai oferecer aos compradores do seu chevrolet volt um período de oito anos, a garantia de 100.000 milhas da bateria de lítio-íon de 161 componentes.
a garantia também inclui o sistema de bateria de gestão térmica, sistema de tarifação e componentes para veículos elétricos, a gm disse hoje.
o volt, que chega às lojas em outubro ou novembro, pode funcionar por até 40 milhas da bateria antes de mudar para o poder de um motor movido a gasolina. a bateria pode carregar de 8 a 10 horas em poder de 120 volts, ou cerca de quatro horas através de uma conexão de 240 volts.
gm pretende para o período de garantia para dar aos clientes a confiança no volt estranho tecnologia plug-in, disse micky bly, diretor-executivo da gm global de sistemas elétricos, hoje na fábrica da gm da bateria em brownstown township, michigan
" é uma questão menor para os comerciantes, ", disse bly. gm não anunciou a garantia de motor movido a gasolina do volt, mas bly disse que seria pelo menos tão longo como o padrão gm de cinco anos ou 100.000 quilômetros.
a longevidade da bateria do volt decorre em grande parte do aquecimento e arrefecimento líquido do sistema que mantém a bateria na temperatura ideal. o volt é o único veículo de mercado de massa desse tipo com um sistema de gestão líquido potência térmica, a gm disse.
por exemplo, o veículo nissan leaf eléctrico tem uma bateria de ar-refrigerado. nissan não divulgou informações sobre a garantia para a folha, que vai na venda em dezembro.
a planta brownstown tem vindo a construir protótipos para volts desde janeiro e em breve começará a pilhas que vão em veículos destinados a garagens dos clientes.
em: http://www.autonews.com/apps/pbcs.dll/a ... z0tmtinubb
koluirty
Mensagem por koluirty »
as traduções do google são o máximo
Por agora de semi-electrico e assim:
Em breve (espera-se) de Predator 90Ah
Seal
Mensagem por Seal »
é obrigatório.
Tó Miguel
Chevrolet Volt
Mensagem por Tó Miguel »
chevrolet volt: bateria terá garantia de 8 anoschevrolet desfaz dúvidas e esclarece que bateria do modelo eléctrico volt terá uma garantia de 8 anos ou 160 mil quilómetros
uma das principais dúvidas que se levanta quando se fala de carros eléctricos é sobre a durabilidade da bateria e sua manutenção.
para acabar com alguma desconfiança que paira sobre este assunto, a general motors anunciou que irá oferecer uma garantia de 8 anos ou 160 mil quilómetros para a bateria de ião de lítio que alimenta o motor eléctrico do chevrolet volt. a mesma bateria será utilizada no futuro opel ampera.
refira-se, como termo de comparação, as tradicionais baterias utilizadas nos carros «normais» têm uma vida útil de 10 anos - a bateria do volt é composta por 161 células e custa cerca de 10.000 dólares.
o chevrolet volt é um automóvel eléctrico com extensor de autonomia concebido para percorrer até 60 quilómetros com recurso exclusivo à carga existente na bateria de iões de lítio, sem utilizar combustível nem produzir emissões.
quando a bateria do volt deixa de ter carga suficiente e caso não haja acesso imediato a uma tomada de energia eléctrica, entra automaticamente em funcionamento um motor-gerador, que tem como único fim recarregar as baterias e assim aumentar a autonomia, até 500 km.
no entanto, a chevrolet não especificou qual será a garantia do motor de combustão, mas avança que será, pelo menos, a mesma que é dada aos motores dos restantes modelos da marca, ou seja, cinco anos ou 100 mil km.
o modelo eléctrico com extensor de autonomia da chevrolet tem lançamento na europa, agendado para o próximo ano.
http://www.autoportal.iol.pt/noticias/g ... -de-8-anos
Sócio ANE Nº 16
Seal
Mensagem por Seal »
Seal
Mensagem por Seal »
koluirty
seal Escreveu::gnigni:
é obrigatório.
tretas é obrigatório traduzir, não é obrigatório traduzir mal
Seal
Mensagem por Seal »
deixa-te de tangas.
já perco tempo a partilhar as notícias e ainda ia perder tempo a traduzir à manápula... pois claro.
já que te incomoda, traduz como deve ser para o ppl.
koluirty
seal Escreveu:deixa-te de tangas.
[off-topic]
meu caro, isso é a discussão do costume, parafraseando a fabulosa aretha franklin:
"(...) ar ie esse pi ie ci ti , r e s p e c t (...)"
respeito é o princípio fundamental e indispensável para o estabelecimento de relações sociais entre seres vivos, e o respeito é uma coisa engraçada quase mágica, cria-se no próprio individuo, quanto mais o individuo se respeita mais respeito terá pelos outros e mais respeito terão os outros por ele.
isto para te dizer o que aprendi cedo, e que cedo ensinei a quem tenho que ensinar, se é para fazer faz bem, se não deixa fazer quem sabe/quer/pode
[/off-topic]
não percas tempo que tempo é coisa que não se recupera nunca...
Tó Miguel
então vamos lá acalmar os ânimos e voltar ao tema : ideia : ... e sempre que possível em português correcto.
Sócio ANE Nº 16
koluirty
tó miguel Escreveu:então vamos lá acalmar os ânimos e voltar ao tema : ideia : ... e sempre que possível em português correcto.
ta tudo carmo isto é discussão de conceitos já velha
Seal
Mensagem por Seal »
koluirty Escreveu:
[/off-topic]
então isso só significa que o meu respeito pelos outros é enorme, pois tenho 2 fóruns e ainda "perco" tempo a vir a este colocar notícias para partilhar com quem aqui anda. espectáculo.
e mais ainda, respeito as regras e coloco sempre a tradução, mesmo não concordando, mas como respeito os outros e devemos respeitar as regras de uma sociedade ou neste caso fórum, faço-o.
obrigado pelo esclarecimento, há muito tempo que não me sentia tão bem, não fazia ideia que era tão respeitado e tão respeitador
eucurto
Mensagem por eucurto »
press release oficial sobre as baterias/garantia.
Chevrolet Volt_Bateria com garantia de 8 anos 0710.pdf
(44.06 KiB) Transferido 2001 vezes
eucurto
PREÇO DO VOLT ANUNCIADO: $41.000
http://green.autoblog.com/2010/07/27/20 ... -lease-fo/
general motors' recently hired vice-president for sales and marketing joel ewanick took the stage at the plug-in 2010 conference in san jose, ca today and finally revealed that the 2011 chevrolet volt will have a base price of $41,000 (including the $720 destination charge) before federal and state tax incentives. while gm hasn't gone as aggressive as most people had hoped on the sticker price, the real deal appears to be the $350 per month for a 36-month lease. that matches the monthly payment that nissan is charging for the leaf electric car.
tradução ranhosa do google:
recentemente contratado general motors vice-presidente de vendas e marketing joel ewanick subiu ao palco no plug-in 2010 conferência em san jose, ca hoje e, finalmente, revelou que o 2011 chevrolet volt terá um preço base de $ 41.000 (incluindo o destino $ 720 carga) antes federais e estaduais de incentivos fiscais. embora a gm não foi tão agressivo como a maioria das pessoas esperavam no preço de etiqueta, a coisa real parece ser a 350 dólares por mês para um contrato de 36 meses. que corresponde ao pagamento mensal que a nissan está a carregar para o carro elétrico leaf.
Monty
Mensagem por Monty »
eucurto Escreveu:press release oficial sobre as baterias/garantia.
"press release" ou "distribuição para a imprensa"?
sergio ferraz
Mensagem por sergio ferraz »
http://media.opel.pt/content/media/pt/p ... experience
antonio gonçalves ganha um opel ampera em uma competiçao de conduçao ecologica
sergio ferraz Escreveu:http://media.opel.pt/content/media/pt/p ... experience
não esclarecem se "pulse & glide" era permitido, o que pode fazer uma grande diferença.
sergio ferraz
os veiculos usados não eram hibridos
acho que valia todos os truques
Seal
Mensagem por Seal »
muito bom sortudo, agora tem é de esperar que o carro saia da linha de produção.
