Noticias de Eléctricos!
Re: Noticias de Eléctricos!
the blue-will concept is powered by an all-aluminum 152hp gasoline direct injected 1.6l which is coupled to a continuously variable transmission and a 100kw electric motor which is at the heart of hyundai’s proprietary parallel hybrid drive architecture. wheels are turned by power coming directly from the gasoline engine, or the electric motor, or both together, as conditions demand. this parallel hybrid drive architecture serves as the foundation for future hyundai
hybrids, starting with the next-generation sonata in the u.s.
for maximum luggage space, the fuel tank is under the rear seat where it is neatly bundled alongside the lithium ion polymer battery which can be recharged using a household current. hyundai will be the first automaker in the world to apply lithium ion polymer in a mass production vehicle this july when the elantra lpi hybrid electric vehicle goes on sale in korea.
eco-sleeker" was the core concept driving the design process. its sweeping character lines and detailed form elevate this next generation hybrid to an entirely new level. blue-will's sleek surface treatment extends to the underbody where a full-length cover has been applied to minimize aerodynamic drag whilst maximizing fuel economy.
the led panel on the front expresses a highly distinctive, futuristic image. the rear bike rack, neatly integrated into the trunk, adds an extra
measure of convenience. to minimize weight, advanced materials such as carbon-fiber reinforced plastics and nano composites have been applied to the side sills, moldings and fenders.
recycled pet material was used for the headlamp bezel, while use has also been made of pla and pa11 bio-plastics on interior and exterior parts.
thanks to the rapid advances in information technologies, designers have been a completely free hand to redefine the interior space achieving a "digital flow" throughout the cabin space. the conventional gauge cluster has been replaced by an ultra-thin transparent organic light emitting diode display mounted on the steering column which is adjustable for rake and distance. thin-film toled technology allows information to be displayed in full high resolution color.
the center stack is normally a very busy area in terms of the number of controls that must be packed into a small area but hnd-4 designers have achieved a remarkably simple and clean look thanks to high-tech touch-screen control technology which extends operability to the hvac, drive (prndl) selector and infotainment systems. the focal point is the eco-coach, a graphic display which helps promote fuel-saving driving habits by providing continuous feedback on fuel consumption and driving efficiency. infotainment capabilities include bluetooth-enabled speakers.
in hyunday
hmgp
Mensagem por hmgp »
"veículos eléctricos reduzem custos de mobilidade"
http://www.autohoje.com/index.php?optio ... itemid=360
ora de acordo com a noticia, com apenas 160.000 veículos eléctricos reduzíamos a nossa factura de 11 mil milhões de €'s em 2 mil milhões de €'s!
ora o nosso governos "chupa" vá lá, pelo menos 50% em impostos nos combustíveis logo mil milhões de €'s para o lixo? nãããã, lá vamos que ter que ser nós a conseguir uma rede de postos de abastecimento... e vamos conseguir!
claro que eles não contam com o facto de que em caso de crises de petróleo não "sofríamos" da mesma forma, que não pagávamos taxas por exceder cotas de co2, ajudávamos a amenizar o clima e os seus "humores", etc., etc., etc. mas isso sou eu que sou um lírico...
Blogue.
+22222Km
Bruce Calvert
Gandhi
hmgp Escreveu:"veículos eléctricos reduzem custos de mobilidade"
esse é um dos verdadeiros problemas, lá está a receita do estado a reduzir, o pib a descer, certo que assim dependemos menos do exterior e evitamos mais a divida externa, de facto este é para mim o melhor da situação.
migjac
chargecar
Mensagem por migjac »
hoje vem um artigo interessante no site www.inovacaotecnologica.com.br:
recomendo uma leitura.
www.chargecar.org
http://www.inovacaotecnologica.com.br/n ... 0170091127
most car makers would like to add an electric vehicle to their line-ups. but fulfilling such an objective isn’t easy – unless a company you share a product with has already done the hard work.
so for citroen, extending its relationship with mitsubishi to re-badge the japanese maker’s electric city car must have been a no-brainer. the result is the c-zero – a new version of the zero-emission i-miev.
and re-badged is the best way to describe it. while citroen has replaced mitsubishi’s three diamonds with its own double chevrons on the bonnet, in every other way the c-zero is visually identical to its japanese cousin.
it looks oddly narrow on the road, but there’s plenty of room for four adults inside. and even though a 47kw electric motor sits beneath the load space, there’s still a 166-litre boot.
power
the motor draws its power from 88 lithium-ion cells stowed beneath the floor. these are charged simply by plugging into the mains. the only drawback is that a full top-up takes six hours from a domestic supply – it’s less from a commercial output.
keyless go is standard so, as long as the fob is in your pocket, all you have to do is turn a switch on the steering column and a beep tells you the car is ready to go. slot the shift lever into ‘drive’ and the c-zero moves off, accompanied only by a muted swish of tyres on tarmac.
the engine provides its full 180nm of torque throughout the rev range, giving more pulling power than citroen’s c1 and c2. acceleration is adequate, if not brisk.
despite the skinny tyres, handling is stable. and while the c-zero has been designed for the urban environment, it certainly isn’t disgraced out on the open road.
citroen claims a top speed of 80mph and says the car will accelerate from 37-56mph in six seconds. of more interest is the range. a conservative estimate of 80 miles will be enough for most owners.
rival: think! city
it's been a long time coming, but the norwegian project that started life as a ford is nearly ready. while handling is decent, above 50mph, speed is limited, plus the car has only two seats.
in ae
hmgp
Mensagem por hmgp »
e na américa também vão ter imiev's já em janeiro. nas "geek squads" das lojas best buy.
http://www.autoblog.com/2009/12/03/best ... hi-i-miev/
Blogue.
+22222Km
Bruce Calvert
Gandhi
audi has confirmed it will launch a new electric flagship sports car in the next few years. based on the e-tron concept car, revealed at this year's frankfurt motor show, the production version will launch at the end of 2012 - in a limited production run of 1,000 models.
costing more than the r8 supercar, it is expected the showroom-ready e-tron will carry a price tag of around £120,000. featuring the same lithium-ion battery pack and four electric motors, it will get a new aluminium spaceframe chassis and a lightweight aluminium body, virtually identical to the e-tron concept. what's more the e-tron name will be carried over too - although not in france, where 'etron' is slang for fecal matter.
development has already started on the newcomer. project team leader thomas krauter told auto express: "apart from some of the dramatic aluminium trim pieces, the exterior will stay the same on the production car. we will manage the aerodynamics with an underfloor tray so there will be no large spoilers and the car will maintain its simple look. between now and 2012, our acoustic department will create a synthesised 'engine' sound too, but our biggest challenges will be to keep all the electrical systems cool - and also to integrate the latest battery technology."
in other audi news, the firm has also confirmed its a7 four-door coupe will be unveiled in late 2010, most likely at the paris motor show. rivalling the bmw 5-series gt, it will look almost identical to the sportback concept, but will differ by featuring a skoda superb-style twin-door hatchback while in the back there will be the option of two and three seater layouts. uk sales will start toward the end of 2010 with prices kicking off at £40-45,000.
read more: http://www.autoexpress.co.uk/news/autoe ... z0znz6cyqw
hmgp
Mensagem por hmgp »
Blogue.
+22222Km
Bruce Calvert
Gandhi
hmgp
Mensagem por hmgp »
Blogue.
+22222Km
Bruce Calvert
Gandhi
Mensagem por rocker_pt »
a revista super interessante tem a capa inteirinha dedicada aos ve da renault.
auto hoje, tb fala dos ve e do vw polo 1.2 tdi com o consumo de 3.4l/100km com 87gramas de co2/km
comprei a super interessante (caderno especial), e desta vez vale bem a pena comprar. não existe nada que nós não saibamos, mas está uma boa síntese, em termos das perspectivas para 2010 a 2012 na área dos ve e hibridos
since the 1997 launch, toyota has sold more than 1.5 million examples of the prius. it’s now the world’s most common hybrid – and boosted by fuel prices, legislation and eco issues, its popularity is unlikely to diminish.
this plug-in version is the latest development of the petrol-electric pioneer. toyota admits the appeal of the regular prius is restricted by its limited range on battery power alone. its thinking is that, by fitting a larger cell, the plug-in car can go further on electric only, and the petrol engine need never start. the system can then be recharged at night on cheaper and greener mains electricity.
initially, the firm will release limited numbers of lease-only vehicles so that it can monitor any problems, but we drove an early model to give our verdict.
under the skin, the main difference between the plug-in prius and the standard hybrid is the bigger battery and boosted electrical system. the 98bhp 1.8-litre four-cylinder petrol engine remains the same.
it claims a 10.9-second 0-62mph time and a 106mph top speed, plus an electric-only range of 12.5 to 20 miles. using a 200v supply, the battery can be recharged in 100 minutes, while the equivalent of nearly 100mpg should be possible.
inside is an energy monitor, an orange charge lamp and a preheating/precooling system for when the car is plugged in. pulling away is as simple as in the standard prius: engage drive and press the accelerator. be careful with your right foot and stay below 62mph, and the engine shouldn’t cut in. even if it does, the switch from battery to petrol power is very smooth.
the ride is soft and compliant, and the handling unaffected by the battery’s extra weight. the engine drives the prius directly or produces electricity, which either propels the car or charges the battery. under braking, the alternator generates current to extend the electric-only range. plus, the new set-up gives more overtaking grunt, and minimises the ‘rubber band’ feel usually associated with hybrids.
read more: http://www.autoexpress.co.uk/carreviews ... z0aynukstm
could this be the smartest electric car on the block? smart certainly hopes so as it's building 1,000 of these second generation fortwo electric drives, with the uk receiving 100 cars in london, the south east and west midlands as part of a 12-month trial.
it certainly looks the part, with its green and white paint making it easily stand out from other smarts on the road. like other fortwos, it will be available with both a fixed roof or as a convertible. inside it benefits from all of the safety and comfort features you'd find in a regular smart including air conditioning, power steering, electronic stability control and four airbags.
with just a single forward gear, the fortwo ed is a synch to drive in its natural urban environment. for ease of use, it's right up there with a twist-and-go scooter. there's also the added advantage of no longer having to deal with the smart's usual achilles heal – the jerky semi-automatic gearbox.
ride and handling seem unaffected by the increased weight, with the power steering making the little smart as manoeuvrable as ever.
with the full 120nm of torque available as soon as you press the throttle, the smart ed can hold its own against far more potent machines at the traffic lights. but, after the initial surge, the 20kw motor – the equivalent of 27bhp – is disappointingly sluggish.
an extra 10kw is available for brief bursts, which is useful on steep hills or when pulling out of junctions. however holding your foot flat to the floor for too long seriously reduces its maximum range of around 84 miles. and be sure to steer well clear of motorways as the top speed is limited to just 62mph.
a full charge from a special three-phase supply socket is an overnight task, taking eight hours. however a range of around 20 miles – the average daily commute – can be achieved in two hours.
the fortwo is one of the most convincing electric commuters on the market. it's fun and easy to drive as well as being kind to the environment. however it is disappointingly slow and prohibitively expensive to build. thankfully though, the lease cost of around £700 will initially be subsidised by the government.
rival: mitsubishi i miev
the electric i has already begun its uk trial and so goes head-to-head with the smart. it might not be as handily sized but the extra performance makes it more enjoyable to drive than the fortwo.
read more: http://www.autoexpress.co.uk/carreviews ... z0aynqmho0
read more: http://www.autoexpress.co.uk/news/autoe ... z0ayo1n3qw
hmgp
Mensagem por hmgp »
Blogue.
+22222Km
Bruce Calvert
Gandhi
hmgp
Mensagem por hmgp »
Blogue.
+22222Km
Bruce Calvert
Gandhi
migjac
não percebo uma coisa. se a protoscar consegue fazer um carro com 354cv, uma velocidade máxima de 200 km/h com baterias de 30kwh, carregadas a autonomia máxima do protótipo deverá rondar os 200km, porque é que carros pequenos com potências muito menores não paresentam autonomias muito maiores?
a limitação dos carros eléctricos é o armazenamento da bateria. se tivessemos um carro com 75cv, com umas baterias destas deveriam ter pelo menos o dobro da autonomia apresentada por este carro, tornando-se assim super competitivo.
que vos parece?
sergio ferraz
Mensagem por sergio ferraz »
nao me parece,estes carros tem motores muito eficientes e equipamento muito caro
so quando baixar o preço vemos os nossos melhores e baratos assim vamos andando de bicicleta
migjac Escreveu:não percebo uma coisa. se a protoscar consegue fazer um carro com 354cv, uma velocidade máxima de 200 km/h com baterias de 30kwh, carregadas a autonomia máxima do protótipo deverá rondar os 200km, porque é que carros pequenos com potências muito menores não paresentam autonomias muito maiores?
que vos parece?
o problema é que lançam números para o ar sem sequer testar, 354 cv electricos são o suficiente para deixar a "comer pó" a larga maioria dos super-desportivos a gasolina. apresentar numero não serve de nada, mas tudo bem sempre impressionam e cativam financiadores.
joaquimdelisboa
automóvel: salvador caetano lança autocarro completamente eléctrico
03 de janeiro de 2010, 11:30
porto, 03 jan (lusa) - a caetanobus, do grupo salvador caetano, está a desenvolver um autocarro eléctrico, um projecto de quatro milhões de euros, que, em setembro, vai começar a circular em portugal e na alemanha.
"o desenvolvimento de melhores baterias e com maior autonomia e o anúncio por parte do governo da criação de uma rede de abastecimento para o carro eléctrico levou-nos a retomar o projecto de um autocarro 100 por cento eléctrico", disse à lusa o presidente da caetanobus.
em entrevista à lusa, josé ramos adiantou que o calendário do projecto prevê "em setembro, ter dois protótipos concluídos", acrescentando que "um vai ser testado em portugal e o outro na alemanha", e, no início de 2011, iniciar a produção nas instalações da caetanobus, em gaia.
