construir um motor magnetico.
Energia Magnética / Perpétua
Re: construir um motor magnetico.
Mensagem por Bluesky »
ok, eu tambem tenho todos o episodios até ao 18. mas esta serie é só o começo do novo mundo. vejam o que encontram em alguns foruns ...
one of the most interesting "free energy devices" ever created are batteries made from zpe instead of the normal fuel cells. these were patented in the uk, they work on the principle of an electro-magnetic-vacuum.
batteries are constructed with an outer casing just like ordinary batteries-aa.etc. the inside contains an area of vacuum energy (actually it is two chambers of positive vacuum and negative vacuum), the chambers exchange energy rather like quantum tunneling, the bottom chamber ( lower half of the battery) contains ordinary matter[low energy] , so is infact a negative vacuum with positive charge.
the top half is made from negative matter and is positive vacuum, which has the potential of negative charge. the system uses a potential membrane that causes the chambers to flip back and forth( quantum flip). electrons are transported from - to + and positrons appear back at the low energy chamber.
in essence, the problems started to appear in principle when someone actually weighed ordinary batteries with a full charge, and then again when the batteries had run 'dry'. the difference in weight, according to the measurements, ordinary batteries actually weigh exactly the same when full or empty!
so if a pair of new, double aa duracell batteries cost $1.99, you use them for a while and, according to the wieghts and measures , they contain exactly the same energy 'full or dry'?..so what have you actually used in between?
the zpe low-energy vacuum batteries,actually are self-charging when they are actually in use.
a quick lapse of concentration on my part, i see it is still pending a classification detail?
i will dig out the overall details with regard to the above, plus the 'bose-nova', piston that is at this moment 'un-classified'.
for your eyes only:
http://www-rohan.sdsu.edu/~rcarrete/tal ... m-ds03.pdf
http://www.aip.org/pt/vol-53/iss-8/p17.html
em relatos de descrições de testemunhas que viram aparelhos em bases militares subterraneas de operações militares compartimentalizadas como "cristais que brilhavam com uma luz tenue azul e produzia a energia necessária para mover o maglev supersónico subterraneo (em túneis despressurizados)" soa a vós como "um absurdo" mas para mim como uma observação bem feita e óbvia. este individuo esteve perante uma bateria que consiste num cristal policristalino como uma nanoestrutura apropriada que depois de excitado vibra ou entra em ressonância com o éter produzindo continuamente energia, numa descarga estrutural por micro-arcos (dai a luz azulada), ficamos por saber se precisamos de manter a excitação residual ou se depois de iniciar o processo o cristal ressoa por reacção em cadeia continua. john hutchison fez experiencias básica neste campo, temos também as baterias de terra como ainda mais básicas...enfim.
http://www.metacafe.com/watch/1031849/f ... nt_energy/
agora a melhor parte desta mensagem: do mito à realidade ... leiam este tópico offtopic para se enriquecerem... brevemente aqui!
podmod de scott mckie : power on demand modules
http://www.rexresearch.com/mckie/mckie.htm
in a nutshell...
resurrecting 'resonance' theory mckie is a promoter of one particular idea of tesla's, the notion that the power in an electric circuit can be amplified by a phenomenon known as resonance. broadly stated, in a resonant circuit a small flow of electrons can cause a larger amount of electrons to move. this phenomenon was first discovered by tesla and by now is well understood.
the "'93 specs" consist of a device designed with two resonant tank circuits -- so called because they are able to store an electrical charge -- operating alternately. the first circuit can be made to simultaneously charge the second and send electric current out for other uses. the circuits can then be switched so the second recharges the first while also sending current out for other uses.
inside the box are a pair of tank circuits, electric circuits that include both a capacitor -- basically, an electrical storage unit--and am inductor -- basically, a coil. it is the interaction of the capacitor and the inductor that mckie supposes creates resonance.
mckie thinks that if properly devised, the two circuits will produce more power than the total amount of power it took to set them in motion. going "over unity," this is called. he thinks, in fact, the power can be amplified many thousands of times and the device can be disconnected from the power source that started it and continue running. mckie thinks such a system could operate indefinitely.
traduzindo pela alminhas (abreviadamente - numa casca de noz):
renascido da teoria de ressonância promovida de um conceito de tesla, a noção que a potência num circuito eléctrico pode ser amplificada por um fenómeno chamado ressonância. com é vulgar ser mencionado, num circuito de ressonância um pequeno fluxo de electrões pode obrigar o movimento de um largo grupo de electrões. este fenómeno foi descoberto por tesla e actualmente é bem compreendido.
as "especificações de 93" consiste num aparelho desenhado com dois "tanques" de ressonância - assim chamado porque eles são capazes de guardar uma carga eléctrica - operando alternadamente. o primeiro circuito é feito para simultaneamente carregar o segundo e enviar corrente eléctrica para o exterior. depois os circuitos são trocados e agora é o segundo circuito que carrega o primeiro enquanto envia corrente eléctrica para o exterior para outras utilizações.
dentro da caixa (do podmod) existe um par de circuitos "tanque", circuitos eléctricos que incluem um condensador (capacitor) - basicamente uma unidade eléctrica para armazenagem
- e um indutor - basicamente uma bobina. é da interacção do condensador e da bobina (circuito lc) que mckie supostamente cria a ressonância.
mckie pensa que quando devidamente sintonizados, os dois circuitos produzem mais potencia que o total da potencia fornecida para o por em movimento. ir para o "sobre-unitário" (over-unity), como lhe chamam. ele pena, na verdade, que a potencia pode ser amplificada alguns milhares de vezes e desconectada da fonte que dá o impulso de arranque e continuar a funcionar continuamente. mckie pensa que o sistema pode operar indefinidamente.
e mais....
scott claimes to be able to generate output power as much as 4,000 times the input power. prototypes have been built and tested, including independent tests by accredited specialists.
exactamente, o pod mod é um cop 4000 ou superior, e isto só durante um breve instante do impulso inicial. uma pilha de 9 v fará o serviço.
disponivel em offtopic (fora dos topicos) "do mito à realidade", como prometido
http://novaenergia.net/forum/viewtopic.php?f=21&t=13529
pasmem-se ... iman "yt" com 120 mgoe. tecnologias perdidas? não, suprimidas.
http://www.world-enlightenment.com/ocr/ ... rticle.pdf
http://www.esmhome.org/library/yoshiaki ... magnet.zip
http://users.rcn.com/zap.dnai/zeropoint/evbike.txt
aposto que muitos se interrogam como é possivel esconder um segredo com este envergadura das pessoas, a resposta é com muitos meios, muito poder e a maior operação conspiro-desinformativa da história, tão grande como a ignorância das pessoas alvo - a maioria.
no meio instruído e junto dos inventores usam leis e supressão activa e passiva. têm diferentes "equipas" para diferentes missões.
http://www.scribd.com/doc/21510205/free ... uppression
http://www.electrifyingtimes.com/erik_m ... ssion.html
copiem estes ficheiros enquanto estão disponiveis...
caros amigos, hoje deixo um simples link muito significativo, fundamentalmente vou de encontro ao que diz a steorn, edward leedskalnin ( o pioneiro) e muitos outros como vão ver. fundamentalmente da-se a conhecer que se tiverem um toroide negam por completo a lei de lenz num gerador electrico.
http://www3.sympatico.ca/slavek.krepelk ... ields8.htm
a serie ... serao 8 ficheiros grandes - 2 gb cada ao que parece
18
http://www.megaupload.com/?d=r3zsej71
1 a 3
http://www.megaupload.com/?d=xmxpxi8f
gryphus
Mensagem por gryphus »
boas blue, não dá para colocar isso em links mais pequenos? é que se tiver mais de 1gb ele pede conta premium...
"A certeza absoluta é um privilégio de mentes não educadas e dos fanáticos".
ok, gryfus, será feito...
gryphus
muchas gracias blue
irmãos, vamos fazer uma pausa? ok, quem somos nós, perguntam eles? somos os filhos de tesla, os herdeiros da electricidade, do magnetismo e da energia do espaço. jamais do usurpador edison, que nos cria aprisionar à corrente continua e as lampadas de filamento incandescente. precisamos 130 anos para nos livrarmos delas e das suas "melhorias", quando poderiamos usufruir estes anos todos de lampadas fluorescentes como indicava tesla, por fim livres de tudo com leds de alto brilho. mas a melhoria do conceito de tesla estara presente tambem no futuro, com tintas luminoscentes e seres biologicos luminoscentes. do motor de indução à corrente alternada, da energia do espaço às bobinas de tesla. comemoremos isso com uma jaula de faraday vestível! não mais cadeiras electricas, não é melhor diversão a 1 milhão de volts?
voltem a visitar a lutec, estão a remodelar a pagina. até na serie dizem que o motor da lutec não é supra-unitario, mas efectivamente é! nada de extraordinario, por volta de cop 3 pois é um motor tipo ebm, mas a potencia é seleccionada pelo numero de modulos incluidos. serve perfeitamente
http://www.lutec.com.au/
3
http://www.megaupload.com/?d=gjd3sfz4
1
http://www.megaupload.com/?d=1vqjjds8
já ouviram falar de toroides?
http://www.megaupload.com/?d=hpqli0rw
extraordinary conference - tesla society
http://pesn.com/2010/08/15/9501687_tesl ... 10_report/
jack scholze demonstrated how the rodin coil can enhance the performance of an electric motor. he's using a spinning neodymium magnet with a toroid, running at 12 volts and only ¼ amp.
veremos com detalhe como um toroide pode sugar milhares de kilowatts do vazio sem problema. se tiverem a fazer experimentações tenham muito cuidado com os toroides, podem provocar descarga de milhares de volts, especialmente quando pulsados com altas frequências. mantenham sempre circuitos de corte como segurança, monitorizem sempre o que se está a passar no nucleo. a segurança primeiro.
4-15.part3
http://www.megaupload.com/?d=zvgxax36
contemporary researchers are painfully aware of inadequacies in conventional models of physics. in a lively presentation with many slides and demonstrations, greg volk untangled these, showing how natural motions occur and exactly where we should be able to find free energy phenomena. several important definitions were given to help clarify the process of research. "energy is not a thing – it is a relationship.” eventually toroidal structures emerge throughout the universe as a fundamental basis of energy and matter. in the demonstrations it became obvious how these definitions can facilitate research. no summary can possibly do justice to the depth and rich texture of greg's work.
tradução:
""a energia não é uma coisa solitária - ela é uma relação". eventualmente as estruturas toroidais emergiram deste universo como um fundamento básico da matéria e energia."
outra observação, meus amigos, as espirais. as espirais e os toroides estão relacionados, basta pensarem na projecção temporal de um fluxo circulante nessa trajectória circular.
se ainda estão baralhados não se preocupem, com o tempo irão compreender. continuemos...
ok pessoal, vamos então entrar no mundo novo, quem não quiser não deve consultar mais este tópico. vamos então acelerar, agarrem-se ...
"bateria" eléctrica de nathan stubblefield, 8 de março de 1898. exactamente, 1898!
http://www.freepatentsonline.com/0600457.pdf
relacionado com as bobinas de daniel cook, 10 de outubro de 1871. exactamente, 1871!
http://www.freepatentsonline.com/0119825.pdf
http://www.youtube.com/watch?v=vgv-yiq2woe
5
http://www.megaupload.com/?d=fmks2z6v
muito boas noticias, a federação americana de cientistas finalmente já se apercebeu que a supressão tecnologica é feita a bem de uma "segurança nacional", argumento que não serve as pessoas.
http://www.fas.org/blog/secrecy/2010/10 ... _2010.html
http://www.fas.org/sgp/othergov/invention/pscrl.pdf
agora já sabem que os "limites teóricos" anunciados nas faculdades são uma fantasia deplorável e o seu significado resume-se a "o que o governo permite". bem vindos ao mundo livre, o mundo das "oportunidades" ... perdidas.
exemplos: de uma lista de 1971!!!!!! imaginem agora... fiquemos pelas restrições do grupo 11:
grupo xi - fontes de alimentação
- baterias de alta densidade energetica por volume, baterias de funcionamento em altas e baixas temperaturas (como as baterias litio)
- fontes auxiliares electricas funcionando a gás (grupos hibridos)
- baterias de activação térmica (como as zebras)
- celulas de combustivel, celulas onde se trocam os reagentes ou agentes electroliticos (as células de hidrogénio já em 1971)
- baterias electroquimicas (electricidade de uma lenta e controlada reacção quimica)
- conversores termiónicos (convertem calor em corrente electrica, alguns usando elementos radioactivos)
- células bioquimicas e geradores bioquimicos para produção energética
- geradores mhd (magnetohidrodinamicos) (geradores de fluxo avançados - este tópico!)
- painéis fotovoltaicos com eficiência superior a 20%
- sistemas de aproveitamento energético com eficiências superiores a 70% ou 80%
- novas formas de geradores e armazenadores energeticos [para detonadores] (reparem sempre que as novas tecnologias são usadas para fins militares)
- geradores de pulsos [para lasers de alta potencia] (como os ebms)
the federation of american scientists has published an extremely important article entitled invention secrecy still going strong. it comes from a mainstream organization and corroborates information the orion project has presented. we are constantly asked, "if better energy systems exist, why are they not available for public use?" the following article addresses one reason: the systematic suppression of energy inventions by abuse of the national security provisions of u.s. law. this means that thousands of inventions have been suppressed- and more than that number through national security orders not issued via the patent process. this is why the orion project has a specific strategy to develop and bring out to the public such energy inventions: one that stands up to these abuses. with your help we can do it!
"a federação americana de cientistas publicou um artigo importante intitulado - o segredo sobre invenções ainda está forte. vem de uma organização corrente e corrobora (comprova) a informação que o projecto orion tem apresentado. nós somos constantemente interrogados "se melhores sistemas energéticos existem, porque não estão disponíveis para consumo publico?". o artigo em questão dá uma resposta: a sistemática supressão de invenções sobre energia por abuso das provisões em segurança nacional da lei americana. isto significa que milhares de invenções tem vindo a ser suprimidas - e mais do que esse numero através de ordens de segurança nacional não emitidas pelo processo de patentes. essa é a razão pela qual o projecto orion tem uma estratégia especifica para desenvolver e trazer ao publico tais invenções sobre energia: uma das que enfrentará tais abusos. com a sua ajuda iremos conseguir!"
8
http://www.megaupload.com/?d=bqfwd3pd
ok, esclarecendo já que ninguém se pronuncia. tanto nas bobinas de nathan stubblefield, nas bobinas de ar e nas baterias de terra existe uma reacção quimica nos metais, assim desde que seja possivel manter estas baterias-bobina num meio humido ou aquoso electrolitico a erosão dos metais demorará bastante e gerarão electricidade dia e noite.
já nas bobinas de cook a estória é outra, pois a excitação da bobina primária não é efectuada por uma reacção electroquímica mas por ressonância lc. exactamente, extraindo energia por intermédio dos campos magnéticos. mesmo assim não perdem a graça, pois não? são um pé na porta... ainda não estão dentro mas vamos todos a caminho.
http://www.megaupload.com/?d=vlvbcfgs
7
http://www.megaupload.com/?d=qsbpcbou
