em 2015...hum...será que haverá baterias como as de hoje?rjsc Escreveu:espero é que quando eu tiver dinheiro pra trocar de carro eles já vendam o pack de baterias com autonomia para 250 km previsto para 2015.
Nissan Leaf
Re: Nissan Leaf
Re: Nissan Leaf
não percebi o comentário mas ca fica a fonte da notícia:
http://www.treehugger.com/files/2009/12 ... c-cars.php
nissan working on new battery to double the leaf's range by 2015
the key is a lithium nickel manganese cobalt oxide cathode
i'm starting to think that electric car buyers will suffer from the same problem as buyers of consumer electronics: it seems like something better is always around the corner, so why buy now? the nissan leaf ev isn't even on the market yet that its technology is starting to sound passé. the nikkei (reg required) reports that nissan is almost done working on a new battery cell design that could almost double the range of the leaf, and of other future nissan electric cars.
should cost about same as conventional lithium-ion
this is exciting news, and i'm glad to see that nissan didn't just dip its toe in the ev world but is actually putting some serious resources into r&d. few things can have a bigger impact on the electrification of transportation than fast progress in battery technology.
nissan is raising capacity by improving the positive electrode, specifically, using nickel and cobalt, not only manganese. the new battery can store about twice as much electricity as batteries with positive electrodes made only from manganese. it is robust enough for practical use, able to withstand 1,000 or so charge cycles.
nissan estimates that the battery will cost about the same as conventional lithium ion ones to produce, as it contains only a small amount of cobalt, a relatively expensive metal.
via afp, green car congress
hmgp
Autor do tópico - Membro Gold
Re: Nissan Leaf
mas qual leasing manhoso? está tudo incluído! é um leasing como outro qualquer... onde é que está a "manhosice"?tiago_eco Escreveu:a mim ninguém me apanha com esse leasing manhoso
Blogue.
+22222Km
Bruce Calvert
Gandhi
+22222Km
Bruce Calvert
Gandhi
Seal
Re: Nissan Leaf
se houver algum problema em colocar estes links, retirem-nos.
mais sobre o leaf:
http://hibridosclube.com/hybforum/index ... pic=1088.0
http://hibridosclube.com/hybforum/index ... pic=1084.0
mais sobre o leaf:
koluirty
Re: Nissan Leaf
hmgp Escreveu:mas qual leasing manhoso? está tudo incluído! é um leasing como outro qualquer... onde é que está a "manhosice"?tiago_eco Escreveu:a mim ninguém me apanha com esse leasing manhoso
a manhosice está em seres obrigado a fazer um leasing das baterias,e a contratar um fornecedor de energia, para poderes fazer a troca de baterias, nas areas de serviço.
ficas ainda mais "agarrado" do que no caso do fcx com a fuel-cell, não esclareci no tópico da prova oral, mas a honda tem uma estação de hidrogenio doméstica que abastece o carro
hmgp
Re: Nissan Leaf
koluirty Escreveu:hmgp Escreveu:mas qual leasing manhoso? está tudo incluído! é um leasing como outro qualquer... onde é que está a "manhosice"?tiago_eco Escreveu:a mim ninguém me apanha com esse leasing manhoso
pois, mas não é esse o caso! leiam bem as coisas antes de mandar abaixo.
a nissan optou por vender o carro por completo, incluindo baterias. o que lá se diz é que para ajudar a manter o carro acessível, ela própria vai assumir os leasings para manter as prestações baixas, não fossem os bancos, etc. encarecer a coisa por ser tudo novo. mas se quiserem podem comprar o carro. pelo preço que foi anunciado. está esclarecido? e o leaf não tem previsto a troca do pack, a renault é que tem isso previsto. a nissan tem é carga normal e carga rápida já incluído no carro.
o carro é vendido por completo!!!
e parabéns à nissan por ser corajosa por mandar o carro a um preço muito mais acessível do que se pensava que ía ser. com um preço daqueles tanto o imiev como o volt ficam em cheque devido ao preço anunciado.
daí que não existe manhosice nenhuma. espero ter sido claro e ter ajudado a perceber visto continuarem a existir tantas dúvidas...
p.s.: resta aguardar/desejar/pensar positivo por um preço semelhante cá pelo burgo...
Blogue.
+22222Km
Bruce Calvert
Gandhi
+22222Km
Bruce Calvert
Gandhi
Re: Nissan Leaf
e começou a concorrência!
a mitsubishi tinha anunciado tal logo de inicio agora nissan usa o seu poder para baixar preços, mitsubishi estuda fusão com psa, vamos aguardar mais noticias...
quem ganha somos nós!
koluirty
Re: Nissan Leaf
a mim parece-me que o carro que está na foto é um leaf
http://green.autoblog.com/2010/04/11/be ... wap-later/
pode ser vendido completo no japão, cá a renault não ia dar um tiro no pé, e os boys muito menos, queres carro eléctrico tens que fazer contrato com fornecedor de energia, a ver vamos, entretanto o iq ev da toyota sumiu-se... que era outro vendido completo e carregavas em casa...
Seal
Re: Nissan Leaf
a impressão que me dá é que as marcas ainda não sabem muito bem onde ir buscar o dinheiro das manutenções, revisões, reparações, etc... e andam a tentar magicar uma maneira de dar a volta à situação.
não se esqueçam que um eléctrico tem muito menos necessidades de peças e de manutenção que os actuais a ci.
Re: Nissan Leaf
vão ter que se adaptar! antes do advento dos frigoríficos domésticos haviam pessoas que guardavam gelo nas serras de inverno em poços e o vendiam no verão e depois ficaram sem esse emprego. e o mundo ficou muito melhor!seal Escreveu:a impressão que me dá é que as marcas ainda não sabem muito bem onde ir buscar o dinheiro das manutenções, revisões, reparações, etc... e andam a tentar magicar uma maneira de dar a volta à situação.
eu até creio que a não necessidade de tantas peças de manutenção seja assim tão má para as marcas automóveis, pois o custo de armazenamento de peças durante pelo menos 15 anos a que são legalmente obrigadas sai muito caro, e por outro lado, nos modelos de automóvel que vendem muito, começam a aparecer as "peças da concorrência" fabricadas por terceiros que também rebentam imediatamente com os lucros em peças das marcas.
por exemplo, eu fui comprar um filtro de ar para o habitáculo do meu carro (renault clio ii) para eu próprio o trocar e na renault custava 20€, numa casa de peças, um filtro de marca branca compatível custou-me 9.5€. já para carros que vendem pouco, as fábricas de terceiros não investem na produção de peças compatíveis.
já fui ao mecânico mudar os rolamentos do eixo traseiro e eles foram fabricados e fornecidos por terceiros, não pela marca, os filtros de óleo que tenho metido idem e todas as peças que for trocando vou comprar a quem a fabricar mais barato.
logo, as marcas não ganham muito nas peças de desgaste, pois há terceiros a fabrica-las mais baratas.
Seal
Re: Nissan Leaf
tens razão, mas nem todos vão a outras oficinas, quando o carro está ainda em garantia então... têm medo de a perder.
Re: Nissan Leaf
e rjsc, são poucas as pessoas que fazem o que fazes, eu sou um deles, compro as peças e faço a manutenção do meu velhinho corsa, mas tenho local e ferramentas para o fazer, a esmagadora maioria vai à oficina e leva com peças de origem.
Re: Nissan Leaf
normalmente só leva com peças de origem se for à oficina da marca, e pelo menos na minha região, ir à oficina de marca é só quando o carro está dentro da garantia, ou quando as oficinas da concorrência não conseguem resolver a avaria.jmal Escreveu:e rjsc, são poucas as pessoas que fazem o que fazes, eu sou um deles, compro as peças e faço a manutenção do meu velhinho corsa, mas tenho local e ferramentas para o fazer, a esmagadora maioria vai à oficina e leva com peças de origem.
vulgarmente nas oficinas de fora só leva peças de origem quem as pedir, porque assim o mecânico consegue apresentar a factura mais barata e ganhar mais clientes.
Re: Nissan Leaf
aí está uma questão muito importante: a manutençâo
koluirty
Re: Nissan Leaf
os meus carros só fazem revisões e reparações na marca, as peças que levam são fabricadas por 3ºs normalmente mas garantidas pela marca.
assim tenho um carro com 8 anos em que confio como no dia em que saiu do stand, não tenho tempo, vagar, meios e conhecimentos para ser eu a fazer o serviço, e não confio no xico manel da esquina, pois se ele se enganar ou esquecer de qualquer coisa não há como exigir responsabilidades.
mais a mais conhecendo eu como conheço a mentalidade tuga lol
Re: Nissan Leaf
rjsc Escreveu:normalmente só leva com peças de origem se for à oficina da marca, e pelo menos na minha região, ir à oficina de marca é só quando o carro está dentro da garantia, ou quando as oficinas da concorrência não conseguem resolver a avaria.jmal Escreveu:e rjsc, são poucas as pessoas que fazem o que fazes, eu sou um deles, compro as peças e faço a manutenção do meu velhinho corsa, mas tenho local e ferramentas para o fazer, a esmagadora maioria vai à oficina e leva com peças de origem.
sim, exacto, mas quantas vezes o mecânico não "impinge" peças da marca, para ele é mais rentável, porque lhe dá uma margem maior e menos problemas, eu não "paro" muito tempo em mecânicos que só me querem vender peças concorrência, não me mostram muito profissionalismo, peças da concorrência são mesmo isso, de concorrência, muitas de boa qualidade e outras nem por isso. dou um exemplo, escapes da concorrência daqueles a 50 euros, nem pensar, duram metade do tempo dos da marca e custam apenas metade, posso dar outros exemplos do que já me aconteceu, triângulos de direcção, escovas limpa vidros, bomba de água, entre outras que ao fim de pouco tempo berram.
mas isto sou eu.......
mas tal como disse existem muitas marcas da concorrência, obviamente existem melhores e piores, e o bom mecânico conhece-as.
ainda assim dá para ver o volume de negócio para este sector gera, dá que pensar.
Re: Nissan Leaf
ao que parece a maior despesa que o meu carro me dá é em pneus, e vou continuar a tê-la com um ve, e se calhar agravada pois com um ve já não vou ter aquele sentimento de culpa de quando se pisa o acelerador dum carro a gasóleo a fundo e fica uma nuvem atrás.
já fui obrigado a fazê-lo 2 vezes na vida para me meter na auto-estrada e quando olhei para o retro-visor senti-me mesmo mal...
(não será 100% verdade no meu caso, porque o comprei usado quase na altura de trocar a correia de distribuição e filtro de ar. se o tivesse desde novo a maior despesa seria em pneus, seguida do óleo+filtros)
Re: Nissan Leaf
se formos a pensar nisso, o mundo não anda para a frente.jmal Escreveu:ainda assim dá para ver o volume de negócio para este sector gera, dá que pensar.
quando o e-mail (internet, por extensão) se começou a generalizar, os correios também achavam que iam ter grandes perdas e no entanto, com o aparecimento das lojas on-line só tiveram a ganhar com o transporte de encomendas.
coitadinhos dos fabricantes de velas, candeias a petróleo e gás quando apareceu a iluminação eléctrica.
coitadinhos dos fabricantes de motores a vapor quando apareceu o motor de combustão interna.
coitadinhos dos operadores de navios de passageiros quando apareceram as linhas aéreas.
coitadinhos dos vendedores de garrafas de gás e esquentadores agora que o solar térmico está a começar a "pegar". (este exemplo parece aproximar-se bem ao que vai acontecer ao mercado dos ci quando os ve começarem a "pegar")
(lista continua com muito mais exemplos...)
não podemos andar com esses medos senão o mundo nunca melhora.
venham os ve, que os mecânicos vão continuar a ter pneus e rolamentos pra mudar, assim como módulos de controlo, como já hoje se fartam de mudar em automóveis a combustão, plásticos partidos, vidros que não fecham, portas que não abrem, pinturas, etc...
Re: Nissan Leaf
??? como consegues gastar mais pneus que combustivel ???rjsc Escreveu:ao que parece a maior despesa que o meu carro me dá é em pneus, e vou continuar a tê-la com um ve, e se calhar agravada pois com um ve já não vou ter aquele sentimento de culpa de quando se pisa o acelerador dum carro a gasóleo a fundo e fica uma nuvem atrás.
num ve sim acredito e a minha scooter é o exemplo disso, aos 4000 kmh levou um pneu de 45 €, e agora com perto de 7000 estou já a pensar no próximo, que não deve durar mais 2000, nestes 5000kmh não gasto 45 euros de energia eléctrica, nem metade disso.
Re: Nissan Leaf
errr... eu estava a pensar apenas em partes não combustíveis (peças)...jmal Escreveu:??? como consegues gastar mais pneus que combustivel ???rjsc Escreveu:ao que parece a maior despesa que o meu carro me dá é em pneus, e vou continuar a tê-la com um ve, e se calhar agravada pois com um ve já não vou ter aquele sentimento de culpa de quando se pisa o acelerador dum carro a gasóleo a fundo e fica uma nuvem atrás.
