Luta Contra o H1N1 (Diga Não ao H1N1) Não Seja 1 COBAIA!
Enviado: sábado jul 04, 2009 8:24 pm
por HighTech
é muito importante que não passe por um simples ignorante!
faça um esforço e tradusa este texto e informe-se sobre este assunto!
pois è a sua saude que conta e as vacianas que vem a caminho nem foram testadas! mas bom são voçes è que sabem!
how to protect yourself without dangerous drugs and vaccinations
last but not least, let me reiterate the many ways you can protect your health from any kind of flu, without a potentially dangerous vaccine.
i have not caught a flu in over two decades, and you can avoid it too by following these simple guidelines, which will keep your immune system in optimal working order so that you're far less likely to acquire the infection to begin with.
*optimize your vitamin d levels. as i've previously reported, optimizing your vitamin d levels is one of the absolute best strategies for avoiding infections of all kinds, and vitamin d deficiency is likely the true culprit behind the seasonality of the flu -- not the flu virus itself.
i would strongly urge you to have your vitamin d level monitored to confirm your levels are therapeutic at 50-70 ng.ml and done by a reliable vitamin d lab like lab corp.
if you are coming down with flu like symptoms and have not been on vitamin d you can take doses of 50,000 units a day for three days to treat the acute infection. some researchers like dr. cannell, believe the dose could even be as high as 1,000 units per pound of body weight for three days.
however, most of dr. cannell's work was with seasonal and not pandemic flu. if your body has never been exposed to the antigens there is chance that the vitamin d might not work. your best bet is to maintain healthy levels of vitamin d around 60 ng/ml.
*avoid sugar and processed foods. sugar decreases the function of your immune system almost immediately, and as you likely know, a strong immune system is key to fighting off viruses and other illness. remember that sugar is present in foods you may not suspect, like ketchup and fruit juice.
*get enough rest. just like it becomes harder for you to get your daily tasks done if you're tired, if your body is overly fatigued it will be harder for it to fight the flu. be sure to check out my article guide to a good night's sleep for some great tips to help you get quality rest.
*have effective tools to address stress. we all face some stress every day, but if stress becomes overwhelming then your body will be less able to fight off the flu and other illness.
if you feel that stress is taking a toll on your health, consider using a tool such as meridian tapping techniques, which is remarkably effective in relieving stress associated with all kinds of events, from work to family to trauma. you can check out my free, 25-page manual for some guidelines on how to perform this simple technique.
*exercise. when you exercise, you increase your circulation and your blood flow throughout your body. the components of your immune system are also better circulated, which means your immune system has a better chance of finding an illness before it spreads. you can review my exercise guidelines for some great tips on how to get started.
*take a good source of animal-based omega-3 fats like krill oil. increase your intake of healthy and essential fats like the omega-3 found in krill oil, which is crucial for maintaining health. it is also vitally important to avoid damaged omega-6 oils like trans fats as it will seriously damage your immune response.
*wash your hands. washing your hands will decrease your likelihood of spreading a virus to your nose, mouth or to other people. be sure you don't use antibacterial soap for this -- antibacterial soaps are completely unnecessary, and they cause far more harm than good. instead, identify a simple chemical-free soap that you can switch your family to.
*use all-natural 'antibiotics'. garlic works like a broad-spectrum antibiotic against bacteria, virus, and protozoa in your body. and unlike with antibiotics, no resistance can be built up so it is an absolutely safe product to use. however, if you are allergic or don't enjoy garlic it would be best to avoid as it will likely cause more harm than good.
other all-natural antibiotics include olive leaf extract and oil of oregano.
*avoid hospitals and vaccines in this particular case, i'd also recommend you stay away from hospitals unless you have an emergency, as hospitals are prime breeding grounds for infections of all kinds, and could be one of the likeliest places you could be exposed to this new bug.
Re: Luta Contra o H1N1 (Diga Não ao H1N1) Não Seja 1 COBAIA!
Enviado: sábado jul 04, 2009 9:54 pm
por Bluesky
cuidado hitech, a ignorançia passa frequentemente pelo pânico e pela desconfiança. estudem o virus e compreendam...
Enviado: sábado jul 04, 2009 10:28 pm
por José Luís Cabete
isto dos vírus hn1hn5 e não sei que mais, não será como os da net? é que de vez em quando aparecem novos modelos e versões.:
ps. cheira-me que isto deve dar muito pilim.
Enviado: sábado jul 04, 2009 11:12 pm
por HighTech
cuidado bluesky nao faças parte da má desinformação, mas sim da boa imformaçao!
chegaste a traduzir o texto?
o corpo ganha resistencia ao virus.
as pessoas mais fragilizadas ou doentes ou com carencias, è normal que adoeçao mais rapidamente se apanharem este virus ou outro qualquer.
o h1n1 è uma uma combinação (mistura) de 3 virus, humano, suíno e de aves, niguem sabe exatamente como ele foi criado ou porque ele surgio asim derepente numa pocilga de porcos no mexico e como è que ele vai agir!.
portanto consuante os casos de infecçao do viros h1n1 vao surgindo, a faze de alerta vai aumentando e quando a faze de alerta chega ao 6 na escala de pandemias, autorizaçoes sao dadas as industrias farmaceuticas para criarem e formularem rapidamente vacinas e medicamentos para entrarem nos mercados mundialmente que nao tem nessecidade de serem testadas cuidadosamente e a tempos!
os riscos estao ai! e as misturas manhosas que eles utilizao nesses medicamentos e vacinas formoladas à preçao! criao mais problemas para a saude publica!.
o que intendo pelos comentarios pela net portugesa è que a maioria das pessoas tem medo e quase todos comentao sem cunhecerem os factos!
abre os olhos! vale mais prevenir que remediar!
traduz o texto e faz o mesmo.
Enviado: quarta jul 08, 2009 9:17 am
por visitante
vivam ...
concordo que a melhor forma de protegermos/defendermos o nosso organismo passa muito por aquilo que ingerimos..
o mel..alho..azeite..vinagre..gengibre..gindungo..limão..etc..são dos melhores antibioticos e anti-inflamatorios activos e preventivos naturais que existem..
de fazem uns tempos a esta parte tudo me leva acreditar (existem dados sobre isso) que as industrias farmaceuticas..biologicas e quimicas se articulam muito bem..principalmente quando detidas pelas mesmas corporações empresariais..para criarem doenças para as quais já deteem os medicamentos..exemplos disso não faltam...
abraços
