New Electric Vehicle unicycle
pois é e quem pensa que só nos filmes se vê disto então pensem novamente!
the uno works like a segway - just tilt your body forward to start moving
hold on tight! the world's first unicycle motorbike
a young inventor has created a motorbike with a twist ? it uses two wheels but they are positioned right next to each other, giving it the illusion of being a powered unicycle. and even better, it might help save the planet.
ben gulak has spent several years building the electric uno that uses gyroscopic technology - like the infamous segway commuter device - to stay upright.
the bizarre-looking contraption has only one switch - on or off - and is controlled entirely by body movement.
the rider leans forwards to accelerate to speeds of 25mph and back to slow down. it has two wheels side-by-side and has been turning heads wherever it has been ridden.
ben gulak designed the uno himself with the help of a simple 3d program
the green machine is so small and light it can be taken indoors and carried into lifts - and is recharged by being plugged into the mains.
the wheels are completely independent, allowing the bike to turn on a sixpence and the technology takes the balance and guesswork out of riding a unicycle.
its 18-year-old creator is now looking for investors to get the uno into production and onto the streets.
ben, from ontario, canada, said: "i was inspired to make the bike after visiting china a few years ago and seeing all the smog.
"they all drive little bikes that are really polluting and i wanted to make something to combat that.
"i started with the concept because if something doesn't look cool people just won't be interested.
ben gulak turns heads from onlookers as he rides past them
"after coming up with the concept i started to build it and now have the first prototype and the reaction has been amazing.
"it has two wheels side by side and that means it is easier to turn as they are completely independent and have their own suspension.
"the bike has a 'neutral point' and when you lean forward it accelerates to keep the neutral point in the right place.
"it has a couple of gyros and is basically self-balancing - it takes the guesswork out of riding a unicycle.
"the bike takes a bit of getting used to because you have to learn to trust it. but it doesn't take long.
"it takes any weight and weighs 120 lbs and can fit into a lift so you can take it indoors to charge it up.
"currently it has a top speed of 25mph, but that will be increased greatly with bigger motors.
"it has a range of about 2.5 hours and it is designed for the commute to work through busy towns. i believe this could be electrical alternative to the car. i'm just looking for an investor to help me get it into production."
mais info
pagina oficial!
Re: New Electric Vehicle unicycle
Mensagem por Bluesky »
encontrei alguma coisa sobre o uno...
uno
... e tambem sobre o gator
gator
mas que raio tem a ver o gator com o uno????
mas pareceu me bem grande estilo a pensar que ia afogar o dito e pimba não é que é um barco também!
Barrocas
Mensagem por Barrocas »
a principio pensei que era mesmo uma unicicle, mas afinal tem 2 rodas... um segway diferente fantático para um rapaz de 18 anos
