essa enzima, age sobre resídos celulósicos como bagaço de cana, casca de arroz, bambu, galhos de árvores ( tudo devidamente triturado).
as pesquisas já existem à muito tempo, mas até agora, as enzimas oferecidas, continham custos superiores ao etanol, o que inviabilizava sua comercialização.
mais informações em: http://www.bioenergy.novozymes.com/
e o diagrama do processo: http://www.bioenergy.novozymes.com/cell ... c-roadmap/
e a tradução do google:cellic® ctec2
the first commercially viable enzyme for cellulosic ethanol production
novozymes’ newest cellulase complex can provide more than twice the performance, making it the first commercially viable enzyme for cellulosic ethanol production. this latest advancement in our enzyme solutions is key to bringing cellulosic ethanol to market.
ctec2 works with a wide variety of feedstocks and process technologies. as with our previous cellulosic ethanol enzymes, cellic ctec2 is a concentrated product that is globally available in commercial-scale quantities. but compared to the earlier version, it allows up to a 50% lower dosage, driving the enzyme use cost down to as low as $.50 per gallon of ethanol produced.
cellic ctec2 offers groundbreaking features and benefits
ctec2 provides increased process flexibility, giving you more ways to lower operating and capital costs:
higher conversion yields – ctec2 contains a unique protein complex that improves the enzyme’s performance and reduces dosage. this technology speeds up the conversion process and increases the ethanol yield.
better performance at higher total solids - a new beta-glucosidase delivers better performance when hydrolyzing pretreated lignocellulose substrates at higher total solids. this allows more substrate to be processed, resulting in lower capital costs and higher ethanol yield.
higher tolerance to inhibitors – ctec2 achieves a higher conversion of cellulose, even in the presence of known enzyme inhibitors that have historically adversely affected enzyme performance.
improved performance - compared to the industry-leading cellic ctec, ctec2 has an average performance improvement of 1.8x across a broad spectrum of processes and substrates.
realistic dosing - because it reduces both enzyme dosage and supply chain cost while setting the standard for high conversion of lignocellulose to fermentable sugars, cellic ctec2 is the first commercially viable enzyme solution for cellulosic ethanol production.
cellic® ctec2 feature and benefit illustrations
cellic ® ctec2
a primeira enzima comercialmente viável para produção de etanol celulósico
novo complexo da novozymes celulase pode fornecer mais do que dobro do desempenho, tornando-se a enzima primeiro comercialmente viável para produção de etanol celulósico. este último avanço em nossas soluções de enzima é a chave para trazer para o mercado de etanol celulósico.
ctec2 trabalha com uma grande variedade de matérias-primas e tecnologias de processo. tal como acontece com nossas enzimas anterior etanol celulósico, cellic ctec2 é um produto concentrado que é globalmente disponível em quantidades em escala comercial. mas, comparado à versão anterior, que permite até uma dose 50% menor, levando o custo do uso de enzimas para baixo para um valor tão baixo quanto $ .50 por galão de etanol produzido.
cellic ctec2 oferece características inovadoras e benefícios
ctec2 oferece maior flexibilidade do processo, dando-lhe mais formas de reduzir custos operacionais e de capital:
maiores rendimentos de conversão - ctec2 contém um complexo de proteínas únicas que melhora o desempenho da enzima e reduz a dosagem. esta tecnologia acelera o processo de conversão e aumenta a produção de etanol.
melhor desempenho em mais de sólidos totais - um novo beta-glucosidase proporciona melhor desempenho ao hidrolisar lignocelulose substratos pré-tratados com maior sólidos totais. isso permite que mais de substrato a ser processado, resultando em menores custos de capital e maior rendimento de etanol.
maior tolerância aos inibidores - ctec2 alcança uma maior conversão da celulose, mesmo na presença de inibidores da enzima conhecida que historicamente têm afetado negativamente o desempenho da enzima.
melhor desempenho - em relação ao líder da indústria cellic ctec, ctec2 tem uma melhora no desempenho médio de 1,8 x em um amplo espectro de processos e substratos.
dosagem realistas - porque ela reduz a dosagem de enzimas e os custos da cadeia de abastecimento, estabelecendo o padrão para alta conversão de lignocelulose em açúcares fermentáveis, cellic ctec2 é a primeira solução comercialmente viável de enzimas para produção de etanol celulósico.
ilustrações cellic ® característica ctec2 e benefício
